Results 1 to 5 of 5
Thread: Roof Trouble
    June 9, 2011
    2
    08:58 AM
    Roof Trouble
    Hi everybody, first post!
    Having trouble with my roof here, hopefully someone put there can point out the flaw.
    I've tried creating it as two separate roofs already to no avail.
    I have included three images.
    Also, does anyone know how to create an overhang for an already existing roof
    Thanks!
    Attached Thumbnails Attached Thumbnails Roof Trouble-error-1.jpg   Roof Trouble-error-2.jpg   Roof Trouble-error-3.jpg
    JCM
    JCM is offline
    December 17, 2010
    Pembroke Pines, FL
    567
    02:58 AM
    Welcome to the Forum!
    It may be that the walls are not all equidistant from the center of the polygon. Make sure that they all are otherwise it will give the error if the "math" doesn't work out for the roof
    Think of Right triangles and the slopes if the distance from center is off, not all are going to have the same peak.
    Autodesk Scott D Davis's Avatar
    March 5, 2011
    Southern California
    583
    11:58 PM
    Try changing the Fascia depth to 0 first. Then try setting the Rafter Cut to Plumb Cut (not Two-Cut) next and see if that helps. Also try sketching the roof by drawing your own Octagon (using the polygon sketch tool) rather than using Pick Walls.
    December 13, 2010
    Ambleside, Lake District, UK
    592
    07:58 AM
    To create an overhang for an existing roof - if you have created it using 'by footprint' just edit the roof and select and change the offset of the sketch lines to the walls via the 'Overhang' box in the toolbar.
    June 9, 2011
    2
    08:58 AM
    Many thanks guys for all your help! Apologises for my sluggish reply!
  1. How to Roof Merge/Join to Lower Roof!!
    By crhdesign in forum Architecture and General Revit Questions
    Last Post: April 30th, 2011, 06:48 AM
  2. Roof with different sloping - one roof or individual surfaces?
    By Clogboy in forum Architecture and General Revit Questions
    Last Post: April 9th, 2011, 01:47 PM
  3. Trouble staying logged in?
    By Darryl_S in forum Forum Suggestions and Feedback
    Last Post: January 10th, 2011, 11:46 PM
