Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: Chimney Walls
    "OMG I killed Revit"
    dzatto's Avatar
    December 9, 2010
    5,163
    01:14 PM
    Chimney Walls
    I'm having a slight issue. See attached:
    The wall behind the chimney is part of the main wall. I attached the top of the wall to the roof, but this little nub won't play nice.
    The roof profile does go around the chimney. If I don't do that, the wall acts like it should, but then the roof is inside the chimney.
    Editing the wall's profile doesn't work, either. Well, I guess it would if I edited it up to the bottom of the roof. I don't really want to do that because I want them attached so if I move the roof, it updates automatically.
    Ideas?
    Also, when I tried to add the wall to enclose the back of the chimney, it wouldn't clean up with the adjacent walls. How does everyone else do chimneys?
    Attached Thumbnails Attached Thumbnails Chimney Walls-capture-1.jpg   Chimney Walls-capture.jpg
    Orlando, FL, USA | [email protected]
    2,787
    02:14 PM
    I would not worry about the roof in this case. Just build the walls of the chimney, and then, make a rectangular opening in the roof, which is the projection in plan view of the walls of the chimney. If the slope of the roof changes later, the rectangular opening will adjust to the slope, and the walls will pass through.
    Is this the Bonanza Ranch?
    dzatto's Avatar
    December 9, 2010
    5,163
    01:14 PM
    Nah, this isn't Bonanza! That's being revised. I'm starting on it again tomorrow. I'm just messing around with a tiny, tiny house.
    So, how do I take care of the main wall? Edit the profile? That little nub is part of the main wall.
    2,787
    02:14 PM
    Why don't you treat the walls of the chimney as independent from the main exterior wall? You need to split these segments from the rest. By doing that you treat the chimney as a separate object, so you don't have to deal with Edit Profile.
    dzatto's Avatar
    December 9, 2010
    5,163
    01:14 PM
    Bingo! Okay, that makes sense. Then, at the top I can just paint the surface? cool
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,553
    07:14 PM
    Quote Originally Posted by dzatto View Post
    Set the height of the main wall to the top of the chimney. Create the opening in the roof as desired. Attach the wall to the roof. When I'm correct it should look like you want it.
    dzatto's Avatar
    December 9, 2010
    5,163
    01:14 PM
    Ya know, now that you mention it, that should work perfectly. I didn't even catch that the "nub" was at the roof line level.
    Sweet, two solutions for one problem.
    Alex Cunningham's Avatar
    December 8, 2010
    Northern California
    3,532
    11:14 AM
    I don't deal with chimneys. Problem solved.
    Senior Member rkitect's Avatar
    April 21, 2011
    Oklahoma
    741
    01:14 PM
    You don't deal with chimneys!!! BLASPHEMY! You are destroying one of the sacred elements of architecture; The Hearth! :P
    The one time I dealt with chimneys I just made the chimney a generic model and placed it in the wall and profiled the roof to go around it. Of course, this was a long time ago and I wasn't worried about material take offs... :shifty:
    ALso, tiny tiny house?! I see 2 stories. If this is a tiny house, then what adjective is used to describe my 1200SF house?
    December 8, 2010
    Northern California
    3,532
    11:14 AM
    Well they don't have many needs for fireplaces and hearths in prisons or elementary schools. LMAO
  1. walls and joins
    By jbenoit44 in forum Third party Add-Ins, API and R&D
    Last Post: May 31st, 2013, 06:16 AM
  2. align walls to be parallel
    By t1shep in forum Architecture and General Revit Questions
    Last Post: May 5th, 2011, 03:29 PM
  3. Walls joining up on their own
    By B Arch in forum Architecture and General Revit Questions
    Last Post: April 27th, 2011, 10:21 PM
  4. Panel walls - Again
    Last Post: February 4th, 2011, 02:34 PM
  5. Walls in Coarse detail
    By Galadriel in forum Structure - General Questions
    Last Post: December 23rd, 2010, 05:05 PM
