Donate Now Goal amount for this year: 3000 USD, Received: 3122 USD (104%)
Results 1 to 9 of 9
Thread: Group members had to be "moved to the project"
    Junior Member Scott Deslippe's Avatar
    April 27, 2011
    Toronto, Ontario
    25
    07:47 AM
    Running into this problem at my new firm who do primarily high rise condos.
    Typical floors are done with groups combining structure and perimeter and such in separate groups. A problem that we are coming across is with columns being made part of the group when aligned to a grid I get the following message;
    Warning
    Group members had to be "moved to the project" (removed from their group instance) because they were not consistent with the group type definition.
    By clicking ok it remove the members speciefied from the group and I can't seem to find a way to remedy it.
    Thoughts and solutions would be appreciated.
    Scott
    Senior Member rkitect's Avatar
    April 21, 2011
    Oklahoma
    744
    06:47 AM
    When you align to the grid, are you in group edit mode for those groups?
    Member tidalwave1's Avatar
    December 9, 2010
    Herndon VA
    75
    07:47 AM
    Which particular members? Were any of these 'members' conflicting with something on that particular floor or that particular location? Can you do a screen capture showing the situation? I work in multi-family and there could be a number of issues...
    April 27, 2011
    Toronto, Ontario
    25
    07:47 AM
    revittotd,
    I'm aligning out of the edit mode before it is part of the group. Also have some that are not aligned at all.
    Tidalwave,
    It's just some structural columns, and it shouldn't be conflicting with anything as nothing else has really been added to the model yet.
    April 21, 2011
    Oklahoma
    744
    06:47 AM
    I guess I'm confused. When you do the align, you are aligning the columns to a grid, neither of which are part of a group, yet you are getting a group related warning. Is that correct? If you hit "expand" on that warning dialog, what are the offending members in the warning?
    December 9, 2010
    Herndon VA
    75
    07:47 AM
    Since the issue you are having troubles with involves columns, are the columns tied to a base and a top? Cause groups don't like objects that are tied to levels.
    Check out this blog post that mentions best practices involving groups.
    Maybe that will help?
    Gold Coast
    1,593
    09:47 PM
    Quote Originally Posted by Scott Deslippe View Post
    revittotd,
    Tidalwave,
    You're not telling us which elements are being "(removed from their group instance)", expanding the dialogue box should show you. This is a guess as I'm not up to speed on structural families...Do you have structural elements (like floors or beams) within your group which may be automatically joining with your aligned columns, causing the affected grouped element to differ from the other instances?
    June 25, 2014
    2
    04:47 AM
    Hello all,
    I'm having the same problem with a dumb 2D group of detail lines and fills. I can't even copy and paste or use the add function to get my lines into my group. What gives? Would appreciate any ideas. (using revit 2014)
    thanks,
    Anna
    Ela
    Ela is offline
    April 14, 2011
    4
    10:47 PM
    hi anna did you found any answers about your query?
  1. Numbering Views on a Sheet - Method to "Group"?
    By revit_user in forum Architecture and General Revit Questions
    Last Post: January 9th, 2013, 08:45 PM
  2. Architect Moved Every Level -1"
    By Mr_Greg in forum Structure - General Questions
    Last Post: September 7th, 2012, 03:58 PM
  3. Family Shared Parameter "Group Parameter Under" in a Project
    By Aretap in forum Architecture and General Revit Questions
    Last Post: August 10th, 2012, 10:18 PM
  4. Replies: 0
    Last Post: February 9th, 2012, 01:15 AM
  5. Moved to a new server - "Planned" Downtime
    By Munkholm in forum Forum Suggestions and Feedback
    Last Post: August 19th, 2011, 10:59 PM
Tags for this Thread
