Donate Now Goal amount for this year: 3000 USD, Received: 1975 USD (66%)
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Like Tree2Likes
Thread: how to create a Trespa facade
    April 16, 2012
    Naaldwijk, The Netherlands
    164
    11:43 PM
    Hi guys!
    I was wondering what you guys think would be the best and easiest way to create a trespa panel facade....
    We are planning to use three different layout
    something like this:
    this:
    and a vertical layout with slim but long vertical panels.
    Only way I can think of is creating the panels in a manually created wall component. in that component I would create reference planes and create extrusions from them.
    But that's just my though of it...
    December 21, 2010
    C.LONDON
    3,287
    11:43 PM
    Curtain walls.
    rosskirby likes this.
    December 21, 2010
    Phoenix, AZ
    1,341
    03:43 PM
    For the second image sure... but for the first with the angles? Parts is the easiest, and most direct, method I can think of.
    April 16, 2012
    164
    11:43 PM
    Could you both please be more descriptive?
    How to use the curtain wall.
    and what do you mean by 'parts'?
    Thanks!
    Member cerb0z's Avatar
    July 5, 2011
    Belarus, Minsk
    240
    01:43 AM
    You need full desgned and spec'ed facade system or just "looking right on drawings" version?
    April 16, 2012
    164
    11:43 PM
    Quote Originally Posted by cerb0z View Post
    The looking right on drawing system would suffice for this project.
    we can work out the system more specified in the detail views
    so please tell me how to create it that way.
    If you dont mind im also interested in how you would handle if you created a fully specified system. Just curious about that one, although i dont need it for now
    thanks!
    July 5, 2011
    Belarus, Minsk
    240
    01:43 AM
    Quote Originally Posted by boriskam1991 View Post
    thanks!
    Just create wall material with model hatch in it, you can move model hatch lines in your model, can be in a wall structure with air layer just or separate finish-wall. For first layout use parts or split face tool for wall segments. Also you can adjust texture for realistic/render view to match your lines.
    For fully specified system you will need to use curtain-wall tool with custom panel families for corners, parapets, window covers etc. Then you can spec, tag, dim, color/hatch code them easily. Structural part of facade should be made by structural engineer or specialist, but can be included into same curtain wall or made of second curtain wall, or made of regular structural families (mainly beams). This was discussed on this forum before but no best practice found yet, can be achieved by few methods.
    April 16, 2012
    164
    11:43 PM
    Thanks! I understand what you mean.
    Any way to create a 'real' joint / seam (whats the english name for that?) of about 10mm wide? that you could gives another color?
    lets say I have white panels and would like a 10mm wide black / gray joint in it ? In detail render you would see that.
    Thanks!
    April 21, 2011
    13
    10:43 PM
    Hi Boris,
    I've done this before using a mullion profile with the thickness of the panel and the width of the joint. If it's an air gap I turn the mullions off in VG.
    Works like a charm
    Good luck
    Ron
    July 5, 2011
    Belarus, Minsk
    240
    01:43 AM
    Thanks!
    I believe you need to discover family editor more, you can add panel material parameter there, then even use Randomiser plugin for your needs Once you'll learn how to deal with curtainwalls and systems, family editor for creating new panels and elements creating facades will become easy.
    I've posted this example in another thread.
    Facade.rvt
    veuxx likes this.
  1. Creating relatively complex facade.
    By nPoika in forum Architecture and General Revit Questions
    Last Post: April 5th, 2013, 03:31 AM
  2. What is the best way to create this facade?
    By PHPWill in forum Architecture and General Revit Questions
    Last Post: November 15th, 2012, 04:35 PM
  3. Glass facade
    By Aussiejayne in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: June 7th, 2012, 12:44 PM
  4. Facade refurbishment project
    By Hirvio in forum Architecture and General Revit Questions
    Last Post: November 17th, 2011, 10:13 AM
  5. Unfold Facade
    By pfaudler in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: May 6th, 2011, 07:06 PM
