Donate Now Goal amount for this year: 3000 USD, Received: 2139 USD (71%)
Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By need4mospd
Thread: Overriding Text to be Transparent
    December 20, 2010
    singapore
    88
    12:49 AM
    I'm only now getting into RAC 2013 after working in RAC 2012 for awhile, but for some reason or another, the first thing that I noticed was that you are no longer able to override text to be transparent for a particular view (override graphics \ by element).
    Just wanted to confirm that this is correct and I don't have something funky w/ my Revit. It's not a big issue, but I remember having some cases where transparent text was necessary, but instead of having 2 types of text types for every size (e.g. 1/8" transparent, 1/8" opaque, etc.), I could just have one style that is set to opaque in the type properties, and when necessary, make it transparent by overriding by element.
    Thanks!
    "OMG I killed Revit"
    dzatto's Avatar
    December 9, 2010
    5,183
    07:49 PM
    I've always created 2 different styles for that, even in 2012. I never knew you could override it!
    But no, you can't do it in 2013 that I know of.
    Member need4mospd's Avatar
    March 2, 2011
    Houston
    467
    07:49 PM
    Create two different types per text style in the template or you'll end up with some doofus turning the same style back and forth without realizing he's changing ALL the text in the project. Either that, or you'll get guys creating their own styles and naming it whatever they want, then those styles get transferred from project to project and you end up with 5 different text styles with the same visibility configuration.
    Text 3/32 - Transparent
    Text 3/32 - Transperent
    Text 3/32 trans
    Text 3/32 not opaque
    Transparent Text 3/32
    Text 3/32 Arial Transparent .8 width factor with cheese
    cganiere likes this.
    December 20, 2010
    singapore
    88
    12:49 AM
    Haha I know what you mean need4mospd.
    Thanks to you both for confirming!
  1. Overriding Sweep Visibility???
    By Alex Cunningham in forum Architecture and General Revit Questions
    Last Post: December 14th, 2012, 04:41 PM
  2. Transparent material
    By yil5167 in forum Architecture - Family Creation
    Last Post: June 5th, 2012, 05:14 PM
  3. Overriding multiple dimensions in one sitting
    By viral_mind in forum Architecture and General Revit Questions
    Last Post: November 13th, 2011, 06:44 PM
  4. Not so transparent
    By Vanguard in forum Structure - General Questions
    Last Post: March 31st, 2011, 07:39 AM
  5. Transparent Glass not transparent in Section View
    By Elisa in forum Architecture and General Revit Questions
    Last Post: December 17th, 2010, 05:02 PM
