Donate Now Goal amount for this year: 3000 USD, Received: 1448 USD (48%)
Results 1 to 8 of 8
Like Tree4Likes
  • 4 Post By mark b
Thread: Wall join problem
    December 22, 2012
    6
    10:00 AM
    Wall join problem
    Idea's about this problem?
    I want to create a row of houses with a double wall between the houses.
    I first want to draw the outher walls of all houses, and then the double walls to sepertate the houses.
    When I do this, I het this
    In detail
    But I want to get this:
    (done with photoshop)
    The wals should be disconnected for better acoutic insulation.
    Anyone got an idea how to get this?
    alvast bedankt!
    bob
    Member tuekappel's Avatar
    February 6, 2012
    Frederiksberg, Denmark
    250
    10:00 AM
    i tried it out with "create parts", but it's a mess...-perhaps i'm not that good with parts, but my other suggestion would be to draw three walls, with two different wall types:
    (one is blue, one is red)
    which will give you the wall join you´re looking for:
    If you play it right, placing location lines on top of each other, and constraining them to one another, you can almost consider the three walls as one. there will be issues around wall schedules, but if you use material take-off instead, it should work out fine.
    Moderator mark b's Avatar
    NSW Australia
    1,410
    08:00 PM
    OK this is a very old trick.
    Set up a cavity brick wall with the same "assembly" as shown in image.
    1 Brick wall as structure layer and 1 as a finish layer.
    Now you have to "delete" the function text out of the outer layer.
    Revit will not let you actually delete the text BUT if you "backspace" and leave just 1 letter (or 2) in function type and press OK Revit will actually delete the function type.
    The next time you open "Edit Assembly" the function type will be blank.
    Now as long as the Brick material type is the same in both wall types the wall will join just like you want.
    This wall type is brilliant for drawing full brick buildings where you need continuous cavities.
    If you can't replicate what I have done, open the attached project and copy paste the wall into your project.
    This wall type will also automatically do return (cavity closure) to the ends of full brick walls.
    Attached Thumbnails Attached Thumbnails Wall join problem-wall-properties.jpg   Wall join problem-contiuous-cavity.jpg
    Attached Files Attached Files
    December 21, 2010
    C.LONDON
    3,279
    11:00 AM
    Quote Originally Posted by mark b View Post
    You say that but it's the first time I've ever seen it - and although it's not (presently) much use to me - I shall be bookmarking this one! Cheers Mark.
    December 22, 2012
    6
    10:00 AM
    tx to mark B and tuekappel.
    I tried the tip from tuekappel, but there is no possibility to place windows I think.
    The tip from mark works..
    But the insulation of both walls should be the same.
    When I change the insulation from one wall to an air barrier, or another type of insulation, it changes back.
    here the walls have both same insulation.
    Here I tried to chage one wall to an air barrier
    Orlando, FL, USA | [email protected]
    2,788
    06:00 AM
    Another solution is to handle that T intersection as a model group. Since it is going to be repetitive in the project, every time you need it, you can insert the group again, mirror it, copy it, etc. The group solves the intersection with individual walls. The exterior wall and the double wall in between houses will not need to be modified, and your insulation materials, windows, doors, etc, can work as usual.
    Attached Thumbnails Attached Thumbnails Wall join problem-12-23-2012-3-01-03-pm.jpg
    December 22, 2012
    6
    10:00 AM
    TX for the tip. I also going to try this.
    December 22, 2012
    6
    10:00 AM
    I did some more exercises with the tip from mark.
    The wall is like i want it to be (right frame) But.... The conection t the floor is wrong (left frame).
    when i replace the "function" in "edit assembly" the floor is back where it should be, but the wall join is again wrong.
  1. Wall join
    By senadra in forum Nederlands forum
    Last Post: December 10th, 2012, 09:46 PM
  2. corrugated wall join?
    By nickikristensen in forum Structure - General Questions
    Last Post: April 26th, 2012, 08:03 AM
  3. join Geometry problem
    By Nsync in forum Architecture and General Revit Questions
    Last Post: March 30th, 2012, 10:10 PM
  4. In-Place wall, all to join
    By qutaibah in forum Architecture and General Revit Questions
    Last Post: December 21st, 2011, 08:48 AM
  5. Wall Join With Different Materials
    Last Post: July 18th, 2011, 06:45 PM
