Donate Now Goal amount for this year: 3000 USD, Received: 2050 USD (68%)
Results 1 to 2 of 2
Thread: Pipe segment error
    Member Andres Franco's Avatar
    June 21, 2012
    Lille, France
    298
    10:06 AM
    Pipe segment error
    Hi there, I'm working in a mechanical room and I must put in it some pumps and a couple of tanks, but when I try to connect the pump with the tank Revit shows me a screenshot like that "Revit could not find a matching pipe segment" but if I put the pipes solely without generates any connection with the pump or tank this works fine , I don´t know what i´m missing in it , any suggestion will be appreciated, kind regards.
    Orlando, FL, USA | info@planta1.com
    2,788
    11:06 AM
    Based on the families that you posted in the other thread, the error happens because the diameter of the connector in the tank family does not match any of the sizes listed under "segments and sizes" in the Routing Preferences of the type of pipe that is assigned to the connector; or, because the diameter of the connector is higher than the maximum size specified for that type of pipe. Solution: edit the tank family, and set the diameter of the connector to match one of the diameters included on the list of segments and sizes, one of the sizes that are less or equal to the current maximum size for the type.
  1. Pipe Settings dialog vs Pipe Systems
    By Ch2M_MikeMaloney in forum MEP - General
    Last Post: December 7th, 2015, 08:00 PM
  2. Draw pipe manually out of connector giving error !!
    By ahmed_hassan in forum MEP - General
    Last Post: September 2nd, 2012, 12:05 PM
  3. Multi Segment Grids
    By LeanneZ in forum Architecture and General Revit Questions
    Last Post: July 27th, 2012, 06:21 PM
  4. segment section w/ scope box
    By Ning Zhou in forum Architecture and General Revit Questions
    Last Post: April 5th, 2012, 10:19 AM
  5. Pipe Fitting Connections to each other/NO Pipe
    By se13gits in forum MEP - General
    Last Post: August 17th, 2011, 05:02 PM
Tags for this Thread
