Donate Now Goal amount for this year: 3000 USD, Received: 1448 USD (48%)
Results 1 to 4 of 4
Thread: how to create a wall underneath a staircase
    September 20, 2012
    28
    12:31 AM
    hello, i was wondering...
    how do you create a wall under a staircase? i have a circular staircase and wanted to create a storage room under the staircase. however, i can't seem to get the wall angled directly under the staircase. i can make the wall curved, but is there a way to make it sloped right underneath the staircase as to close off the storage room?
    thank you
    Senior Member PijPiwo's Avatar
    May 20, 2011
    Chicago, IL
    715
    07:31 PM
    Create a curved wall from a floor to ceiling under your stair. To get rid of the part of wall that is above the stair cut it with in-place void form (sweep or swept blend will do). Use the underside edge of stair for your void sweep path.
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    4,849
    08:31 PM
    You can also edit the wall profile, or attach an RP to the bottom of the stair and attach your wall to the RP.
    Triming a curved wall to the underside of a stair
    Attaching Walls to Stair
    http://www.revitforum.org/architectu...e-wall-go.html
    Member Minotaur's Avatar
    July 26, 2015
    117
    01:31 AM
    Man it is 2016. they still didnt solve this basic thing RP i solution...
  1. Staircase Problem
    By andreakset in forum Architecture and General Revit Questions
    Last Post: February 7th, 2012, 05:19 PM
  2. Create Panels on a Wall
    By aprincipe in forum Architecture - Family Creation
    Last Post: December 5th, 2011, 08:46 PM
  3. Replies: 1
    Last Post: September 28th, 2011, 11:08 AM
  4. how to create custom wall (lines of wall are not parallel)?
    Last Post: August 22nd, 2011, 03:11 AM
  5. Staircase
    By Kcooke in forum Architecture and General Revit Questions
    Last Post: December 15th, 2010, 09:25 AM
Tags for this Thread
