Donate Now Goal amount for this year: 3000 USD, Received: 1160 USD (39%)
Results 1 to 10 of 10
Thread: Sloping Chimney Cap
    "OMG I killed Revit"
    dzatto's Avatar
    December 9, 2010
    4,075
    05:30 PM
    Sloping Chimney Cap
    I need help. I've created a simple face based family for a chimney cap. I need the top part to be able to slope to the front. I'm lost on how to do it.
    If possible, I'd like the parameter to have slope input, like roofs do. So, instead of 45 degrees, I'd like to input 12:12 slope.
    Attached Files Attached Files
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,481
    10:30 PM
    Quote Originally Posted by dzatto View Post
    Well, here's it with a slope angle (didn't test it really thorough so you might want to check the constraints...
    There is probably some mathematical way to calculate the slope angle from width and difference in height between front and back, but frankly: I'm on a deadline here...
    Moderator mark b's Avatar
    NSW Australia
    1,069
    08:30 AM
    Here you go. Dont think you can change input from angle to ratio. Could be done by adding a formula thou.
    NSW Australia
    1,069
    08:30 AM
    LOL Now you have 2 to pick from .
    dzatto's Avatar
    December 9, 2010
    4,075
    05:30 PM
    Damn I love this forum! And from two of my favorite members, too.
    Checking them out now. My guess is they are exactly the same.
    dzatto's Avatar
    December 9, 2010
    4,075
    05:30 PM
    I tried the exact same thing, using a reference line, and it didn't work. How did you guys do it, and get the side walls to join at the slope?
    Martijn, you win. Mark sloped it to the side instead of the front.
    I take that back. You've both messed up my constraints in two different ways. I swear, free help is hard to find these days.
    Seriously, though. I'm going to try to deconstruct both of yours and figure this out. It can't be too difficult (I hope). Thanks to you both.
    NSW Australia
    1,069
    08:30 AM
    Yeah but I am in the Southern Hemisphere ! You know the, the water goes down the sink in the opposite direction, front back left right whatever !!
    The chimney is an extrusion drawn in a side view, base and 2 sides locked to planes, sloped top locked to REFLINE
    NSW Australia
    1,069
    08:30 AM
    Also you did align and lock your Refline to both planes at the intersection by Tabbing the end of the Refline untill the blue dot appears and align to plane didn't you ?
    Attached Thumbnails Attached Thumbnails Sloping Chimney Cap-28-07-2011-10-40-32-am.jpg
    dzatto's Avatar
    December 9, 2010
    4,075
    05:30 PM
    Ummmm, yeahhhhhh sure I did.
    AND I must apologize. I looked back at my family at somethings screwed up. I'm thinking it was jacked to begin with. oops.
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,481
    10:30 PM
    Refline is attached to the right side crossing of refplanes. It has a length parameter Width+2*Overhang.
    Refline has an angle parameter (You need to do this BEFORE constraining any geometry)
    I redid the cap in Left Elevation View with the Center workplane as refplane. Cap is locked to refline and to both ends.
    I gave the shaft an extra length (Height + 1') and cut it using a Void hosted to the refline. So it will probably only work on a limited angle (but hey, speed is everything)
    That's about it I guess...
    Sorry, no takebacks. Besides: I warned you...
  1. Curved wall with sloping top
    By Alfienoakes in forum Architecture and General Revit Questions
    Last Post: June 16th, 2011, 08:39 AM
  2. Chimney Walls
    Last Post: May 24th, 2011, 08:47 PM
  3. Sloping pad issue - 2 pads intersecting each other
    By jh75 in forum Structure - General Questions
    Last Post: May 11th, 2011, 02:30 AM
  4. Roof with different sloping - one roof or individual surfaces?
    By Clogboy in forum Architecture and General Revit Questions
    Last Post: April 9th, 2011, 12:47 PM
